2008 Rear Shock replacement
Old Aug 28, 2016 | 12:28 PM
markap12013's Avatar
Default 2008 Rear Shock replacement
I looked into the wheel well and I see the three bolts holding the shock mount to the car - very good, no need to remove the rear seat on the '08 which is great news.
A couple more questions - this will remove both the shock and the coil spring - right? Will the shock then come out from the spring or will I need a spring compressor tool similar to what's used on a strut? Should I consider replacing the springs too (80k miles) and if so, do they come as an assembled unit?
Other than that, it looks very straight forward.
Old Aug 28, 2016 | 04:34 PM
ES6T's Avatar
The shock will drop out. This will not do anything for the spring. No need to replace the springs.
Old Sep 20, 2016 | 04:17 PM
Yes, very easy and quick to do - had to use an impact wrench on the lower bolt (no room for breaker bar). Could have used a 13mm offset box wrench on the shock bolt to swap the mount but was easier just to take it to the repair shop. Whole thing took maybe 45 minutes start to finish.
jared..mann
1998-2000 model year V70
Apr 20, 2013 04:33 PM
paul1149
Sep 6, 2012 11:20 AM
oconnomo
Aug 7, 2009 02:05 PM
940turbo94
Nov 29, 2007 09:39 PM
