99 Volvo C70 vibration
Old Jun 18, 2016 | 05:19 AM
kevin1014's Avatar
Default 99 Volvo C70 vibration
New here & appreciate anyone's input. Just purchased this C70 & pretty handy with minor stuff & usually can find the problem but I'm stuck. when I put the car in drive engine running, I get this odd vibration / pulsation in the passenger front. put it in Neutral it goes away. While sitting if I turn the wheel all the way one way or the other it starts again. Also does this upon acceleration for just a short time & sometimes while turning. Drives nice otherwise. Tried to locate it to no avail, sounds like it's coming from left side of the engine.
Thanks for any input.
Old Jun 18, 2016 | 06:51 PM
I'd look at the motor mounts.
Old Jun 18, 2016 | 07:11 PM
kevin1014's Avatar
Thanks , never thought of those & after you mention it I found some threads. Sounds like a pretty common issue. This could be exactly why I had no idea what it would be.
My thought was driveline or bearings but it seem to do it on Acceleration 5 to 10 mph then goes away ? Sometimes in a standstill in drive. Vibrations ?
Old Jun 19, 2016 | 12:00 PM
wheel bearings typically moan and cv joints make their most noise at full turn. Bearings can also change sound with hard left or right turns (outside wheel gets more weight) but would not be dependent on power on/off. Brakes can make noise too - ie loose or damaged dust shield etc. To check motor mounts/torque rods try this - open the hood and have a partner put the car in gear with full brake. apply small amounts of power and look for any lifting or rocking of the engine. - don't do inside a garage or stand in front of the car in case your partner's foot slips off the brake :-)
Old Jun 24, 2016 | 07:31 AM
Moved to C70 section.
gup900rr
May 25, 2015 09:07 AM
rossg
Nov 9, 2013 06:43 AM
xk150
May 31, 2011 08:32 PM
mick1232
Apr 26, 2009 06:43 AM
ocean238
Apr 17, 2008 06:20 PM
