Blown Amp?
Old Jul 11, 2018 | 01:29 PM
54fighting's Avatar
Default Blown Amp?
I have a 1999. I lost all sound to the side speakers. The fuses in the engine compartment are fine. At least one fuse in the amp itself was blown. When I tried to replace that fuse, it blew immediately (car and radio were off. Does this suggest that my amp is blown? Is there a replacement amp available that would match the existing connections?
Old Jul 12, 2018 | 10:09 AM
what model radio do you have? I'd start by disconnecting the radio and the amp and see if the fuse stays good to rule out a wiring short. To replace the amp, the easy fix is to simply shop eBay or car-parts.com and get a used one for an exact replacement. If you decide to go after market, again eBay, Crutchfields etc sell wiring adaptors (not a fan of cutting and splicing OEM connectors)
Old Jul 15, 2018 | 11:59 AM
54fighting's Avatar
Is pulling the power to the amp insufficient to test? Presumably, I need to pull the radio out to disconnect? Would pulling the fuses in the engine compartment work in lieu?
Old Jul 15, 2018 | 12:30 PM
54fighting's Avatar
I disconnected the power to the amp and the connection to the radio (the pin connector I assume) and pulled the 30 fuse (placement 9) for the amp in the engine compartment. I replaced the two 20 fuses in the amp itself. When I plugged everything back together and inserted the 30 fuse in the engine compartment, the 30 fuse blew. Presumably, that means my amp is good and that I have a wiring short. I'm assuming this means that I have to check the entire electrical wiring run for the amp or is there a likely location that is the culprit. If it is the entire run, any idea how I do that? Thanks.
MichaelTGrubbs
Sep 18, 2019 11:51 AM
nathswansea
May 30, 2012 11:36 AM
rdenham479
Sep 17, 2009 08:08 PM
Lab_Rodent
Nov 15, 2007 08:07 PM
Mark764
Jan 9, 2006 08:54 PM
