Which C70 do I own?
Old Apr 29, 2009 | 02:42 PM
Shiftor's Avatar
Question Which C70 do I own?
Hello fellas, I am new to this forums.
I own a 99' C70 hardtop but it doesn't even have sunroof, so I wonder is my car a 2.3L or 2.4L. engine. And what is the difference between the two.
Thanks in advance.
Old Apr 29, 2009 | 04:15 PM
TIPSP's Avatar
Got Boost?
Which engine do you have?
LPT....B5254T (190hp) 2.4L
HPT....B5234T3 (236hp) 2.3L
https://www.customers.volvocars.com/.../1999_c70.html
Old Apr 29, 2009 | 04:52 PM
reg's Avatar
reg
There is a tag under the bonnet that will spell out the engine number as noted above. Compare your number with what tipsp has related.
r.
Old Apr 29, 2009 | 05:42 PM
PANTYEATR's Avatar
i really can't understand why volvo would give a weaker, slower model more displacement than the stronger, faster model.
so, it's safe to say that if you hot-rod both with the same mods and boost pressure, the LPT C70 would beat the HPT. or am i crazy???
Old Apr 29, 2009 | 06:59 PM
nolyaw's Avatar
The lower dis. engine has a lower compression ratio, allowing it to run more boost. 10 hp per add. lb. of boost. LPT runs about 8.7 lbs, HPT runs about 12 lbs. Factory, of course.
Old Apr 29, 2009 | 08:34 PM
Shiftor's Avatar
All i found was a screwed metal plaque on the inside left of the engine panel.
872 X J 011621 / 31
/ 1370
/ 426-26
/ T51SBMS5
I didn't find anything under the hood.
Old Apr 29, 2009 | 09:44 PM
TIPSP's Avatar
Got Boost?
It is the Emission sticker on the firewall.....I think it is on the passenager side.
FYI....dont post your VIN....
Old Apr 29, 2009 | 11:12 PM
Shiftor's Avatar
Where exactly is that located at? I don't know what a firewall is.
About VIN #, advice taken, ty.
EDit- Btw, I don't want to flood the forum nor make myself annoying. I received a letter from Volvo about three weeks ago that I should take my car in to a local Volvo dealership because some volvo makes that included a few 1999 makes had some kind of issue with some electric throttle something and that they at no charge would upgrade the software.What is this concern they mention about?
Old Apr 30, 2009 | 09:36 AM
elav's Avatar
It is a recall for the ETS. They reprogram it and clean the contacts. There is an issue that can result in sudden loss of power which can be very dangerous.
Old Apr 30, 2009 | 11:25 AM
mkc70's Avatar
Read your VIN#, use the breakdown:
http://www.volvoclub.org.uk/vin_70.shtml
You will only have two engine code choices for the US market.
Old Apr 30, 2009 | 04:40 PM
PANTYEATR's Avatar
yeah i understand that, but if you boost both engines to lets say....15psi with all the appropriate mods to support that, the higher compression engine in theory should produce more power cause the compression ratio is higher.
i know some turbo eclipses that have forged internals, but retained the factory compression ratios that produce over 400hp with only 9-10psi of boost. the only problem with high compression and boost is the higher the compression and the boost, the smaller the tuning window you have and the less room you have to make a mistake before your engine craps it's guts on the street.
Old Apr 30, 2009 | 06:14 PM
TIPSP's Avatar
Got Boost?
Yes it would...
RSI might have a stroker kit now for the whiteblocks.....if you want to spend some money .
Old May 1, 2009 | 07:16 PM
Shiftor's Avatar
I own a ..
*Drums*
2.4 LPT.
I coulda sworn this car had more HP than 190, engine is stock, but the car flies like a missile.
Old May 2, 2009 | 12:57 PM
PANTYEATR's Avatar
Originally Posted by Shiftor
I own a ..
*Drums*
2.4 LPT.
yeah flies like a missile once it's already moving. it's just too damn slow to get out of its own way though. i too own a 2.4 LPT ;(
schoolloans
Jun 18, 2009 08:34 PM
ko_kidd
Aug 25, 2006 08:53 PM
lisrobbe
Feb 25, 2006 02:33 AM
s40volvoH
Mar 22, 2005 09:53 AM
wilcalak
Feb 1, 2005 09:54 AM
