c70 t5 1998
Old Nov 20, 2011 | 12:30 PM
TONY12340's Avatar
Default c70 t5 1998
hi every one
the cruise control has stopped working on my 1998 c70 T5
can any one help??
Old Nov 24, 2011 | 04:37 PM
MSGTUSMC's Avatar
Check fuses? Sensor? Chilton Repair Manual, pg 6-16 troubleshooting: Cruise control inoperative. 1. blown fuse. 2. Short or open in cruise control circuit. 3.Faulty brake or clutch switch. 4. Leaking vacuum circuit. 5. Faulty cruise control switch. 6. Faulty stepper motor. 7. faulty transducer. 8. Faulty speed sensor. 9. Faulty cruise control module. I would check & clean all wheel sensors 1st.
Old Nov 26, 2011 | 04:52 PM
TONY12340's Avatar
hi thanks for your post
i dont have a chilton repair manual...i only have the haynes manual which says problems should be refered to a volvo dealer
Old Feb 8, 2015 | 01:53 PM
Racerxc70's Avatar
(no joke) On the way back from the beach my CC stopped working, when I got home I started tracing back the CC vacuum line, there is a connection behind the left front headlight, what I found was that the vacuum tube had been chewed through by the ground squirrel that had hitched a ride in my GRILL and was still there, peering up at me, I cut away the damaged part of the tube and reconnected it. ( yes I did drive back to the beach and waited for the squirrel to vacate)
C70CoupeMaui
Feb 25, 2008 09:38 AM
C70CoupeMaui
Feb 24, 2008 07:12 PM
pilot60378
Apr 27, 2007 03:26 PM
Adsonic
Sep 19, 2006 08:37 PM
snulma1
Jun 19, 2006 03:52 PM
