I have 3 questions for my 1998 C70
Old Sep 16, 2006 | 01:34 PM
Adsonic's Avatar
Default I have 3 questions for my 1998 C70
It’s my first post so …. Hello everyone [sm=happybounce.gif]
Ok I have a problem and don’t know what it means, when I turn the A/C on and after a few seconds I see both the “off” and the recycle / internal air light blinking together.
Also another small thing, some times at the stop light it stalls a little and shake but just for a second…. Is that normal?
One last thing, is there any chance I could buy a software that could reprogram a remote and also can read any stored codes?
Thanks in advance,
Adsonic
Old Sep 17, 2006 | 12:41 PM
Default RE: I have 3 questions for my 1998 C70
1. You have codes in the A/C system thats why the lights blink.
2.You might want to check for tune up and make sure the throttle body isn't dirty.
3.The Dealer needs to program the remove.
Yours is a 1998 if you get a decent scanner you should be able to read and clear codes.
Old Sep 17, 2006 | 01:41 PM
Adsonic's Avatar
Thanks for the reply, I really appreciate it …
But one small note about the scanner, wouldn’t it be cheaper to buy a PCM cable and use a free (if passable) software to read the codes? I’m only checking cus I’m used to pulling the codes of my Impala SS PCM (OBDII) like that.
Anyway, I checked E-Bay and found this scanner … what do you think of it? Is it good enough for the job?
http://cgi.ebay.com/ebaymotors/OBD2-...QQcmdZViewItem
Thanks,
Adsonic
Old Sep 18, 2006 | 08:33 PM
That scanner should do the job. You could try the other setup on the Volvo but not sure it will work.
Old Sep 18, 2006 | 08:49 PM
Adsonic's Avatar
I'll get that scanner, thanks for everything.
P.S: love the wing on your Mustang
Old Sep 18, 2006 | 09:19 PM
Thanks but kind of looking for a 850 one for the car.
That used to have side wings on it but the plastic broke off.
Old Sep 19, 2006 | 11:18 AM
Adsonic's Avatar
Never the less it still looks great [sm=smiley20.gif]
Old Sep 19, 2006 | 08:37 PM
ORIGINAL: Adsonic
Thanks more to come Slowly.
CodyGaul
Feb 14, 2014 10:20 AM
melibbys
Oct 19, 2013 01:11 PM
Phil 850
Jul 25, 2012 10:01 PM
snulma1
Jun 19, 2006 03:52 PM
