Getting wires through the wirewall?
Old Dec 30, 2008 | 09:54 PM
Morell64's Avatar
Default Getting wires through the wirewall?
I own a 1998 C-70, I am trying to do a couple different upgrades but so far we have ran into the same problem! I cannot find anywhere to run wires from the cab to the engine through the firewall? Can anyone help?
Old Dec 30, 2008 | 11:31 PM
mkc70's Avatar
Default RE: Getting wires through the wirewall?
If you have searched and can not go through an existing grommet with your power wire then I would advise you make a path. Either go to Sears and buy a titanium unibit and drill the hole where the clutch bracket would be, or go to your local stereo shop and have them drill a hole. Do not forget to use a grommet, I prefer a circuit breaker near the battery and not an in-line fuse.
Old Dec 31, 2008 | 08:19 AM
There should be a tube that is already there from the factory to run wires into the cabin.
It is the corrigated looking wire loom stuff. There is a rubber grommet on the end of it with little nipple looking things on it. You would either poke a hole and feed the wire through or cut the end off and feed it through. It should run through the firewall under the brake booster.
AlexCurran1
Jun 22, 2011 12:15 AM
Shaun Oriold1
Oct 5, 2006 11:56 PM
Psaboic
Jun 6, 2006 01:34 AM
edahlgren
Oct 7, 2005 09:53 PM
