'01 s40 Driver's Window Regulator
Old Aug 3, 2012 | 07:27 AM
crosby1's Avatar
Default '01 s40 Driver's Window Regulator
any help would be greatly appreciated!
the driver's side power window was stuck in the "down" position; i was able to manually push it back up and get it closed.
i've removed the door panel and in testing the window it seems like the motor runs fine; the window just won't go up and down. i've removed the 3 small bolts holding the regulator/motor assembly in place in the hopes of taking it out and seeing what was wrong, but i can't figure out how to get the assembly out from behind the door panel.
i'm missing a trick somewhere.
any suggestions on how to get the assembly out of the door panel and any thoughts on what could be causing the window to not go up and down even though the motor seems to run OK?
thanks so much in advance!
Old Aug 6, 2012 | 07:04 AM
crosby1's Avatar
bump. anybody? please?
thank you
Old Aug 13, 2012 | 09:52 AM
crosby1's Avatar
oh, nevermind.
i figured out how to do it myself.
Old Sep 29, 2012 | 12:10 PM
euroxepouh's Avatar
Originally Posted by crosby1
oh, nevermind.
Hi, I'm having the same issue overhere ...If u don't mind can u share with me how did u fix it? thanks in advance.
Old Sep 30, 2012 | 09:00 AM
Hudini's Avatar
I've done a couple on other cars and it's always a PITA to figure out. Patience and a bit of cussing always helps. My hands have never finished the process without being cut up.
Old Oct 2, 2012 | 06:37 PM
S40 in Fla's Avatar
We brought ours to Volvo a few years ago and it cost about 4 hundred bucks for the new regulator and motor. I learned online how to do a jeeps last year for about a hundred.
Old Oct 14, 2012 | 01:06 PM
urbino's Avatar
Default i replaced my regulator
bought the replacement reg for around 125. im mechanically inclined....took me 21/2 hours....i had all the correct tools...a big help. dealer quoted in pasadena just under 450. for the job.
bcolins
2001-2013 model year V70
Nov 11, 2013 03:56 PM
greenman86
Sep 26, 2013 07:33 AM
quietlymknnoise
Feb 17, 2013 05:15 AM
wildcard442
Apr 11, 2010 09:12 PM
