06 S40 Wheel bearing
Old Aug 4, 2009 | 11:45 AM
volvo-a-gogo's Avatar
Default 06 S40 Wheel bearing
Hi All!
I'm a newbie to the site. I need any info/help/tutorial on replacing wheel bearing from start to finish. I'm assuming it's my right bearing since the noise either stops or reduces when I move the steering wheel to the right, correct? Now, I am not entirely certain if it is the front or back bearing. My steering wheel vibrates/shimmies slightly at certain speeds 35/40mph >. I am not sure if that's a symptom in addiiton to the loud "whoomping" noise. What parts and tools does this require and a good place to purchase those? Estimate of cost? Time? Skill level? I am pretty decent with mechanical stuff so hopefully this is not out of my skill level.
Thank you in advance!
Old Aug 6, 2009 | 11:41 AM
chinohayze's Avatar
If I was you the first thing I would do is get a wheel balance which is inexpensive. I had a similar problem when I changed 4 new tires. 1 of the mechanics didn't balance my wheels correctly. Once they were rebalanced properly the problem went away.
Old Aug 7, 2009 | 07:10 AM
Hey chinohayze-thanks for your advice! Ok, I will get the balance rechecked first. I did get my new tires put on at different intervals-purchased tires for the rear, then probably not more than a month later, bought 2 more tires so they moved the rear tires to the front and new ones went to the back. In retrospect, I think I noticed the noise after the first time. It wasn't that loud so I didn't think anything of it. I also noticed one of the tires-on the rear, I think (I'll check after work)- does not have one of those weights they attach to the lip of the tire rim. Maybe that could be the culprit?
Thanks!
Old Aug 7, 2009 | 01:27 PM
chinohayze's Avatar
You should stand there and watch him balance your wheels. Make sure the numbers on the machine are at 0 after he balances them.
geoduck
Jul 15, 2016 04:18 PM
Volvo Newbie
Dec 28, 2011 09:00 AM
soukio
Nov 15, 2010 01:23 PM
GaMax2k1GLE
Jun 13, 2007 02:24 PM
julyccc
Nov 13, 2004 09:04 PM
