1st 2nd gear changes.
Old May 24, 2026 | 12:56 PM
erfint4's Avatar
Default 1st 2nd gear changes.
Have been reading some forums with same issue im having. Stiff 1st 2nd gear changes. Gets a bit better when warm. Has anyone had this problem and a solution to it? Splines? Mesh? Slave cylinder? Clutch? Oil? Transmission mount?
understand could be either but read many has this problem but haven' found a solid solution or resolved thread.
Old May 24, 2026 | 04:20 PM
I suspect some clutch drag. You can try a transmission drain/fill and go with a premium synthetic gear old like Redline that will help with the cold days but thats dead winter below freezing stuff not when its warmer
Dunno if you have a pedal adjustment option but you should also inspect the slave cylinder for any signs of leaks and consider bleeding the slave to see if there's any air in it
erfint4
May 31, 2026 05:39 PM
erfint4
May 31, 2026 05:38 PM
erfint4
May 31, 2026 10:09 AM
erfint4
May 24, 2026 04:38 PM
erfint4
May 24, 2026 10:54 AM
