Stiff 1st 2nd gear changes
Old May 24, 2026 | 09:16 AM
erfint4's Avatar
Default Stiff 1st 2nd gear changes
Have been reading some forums with same issue im having. Stiff 1st 2nd gear changes. Gets a bit better when warm. Has anyone had this problem and a solution to it? Splines? Mesh? Slave cylinder? Clutch? Oil? Transmission mount?
understand could be either but read many has this problem but haven' found a solid solution or resolved thread.
Old May 24, 2026 | 04:38 PM
most likely is you have some clutch drag. Could be a worn clutch or the pedal needs adjustment or you need to check the slave cylinder for leaks and or bleed any air out
erfint4
May 31, 2026 05:39 PM
erfint4
May 31, 2026 05:38 PM
erfint4
May 31, 2026 10:09 AM
arachnofilas
Aug 20, 2021 12:28 PM
cla6665
Dec 4, 2007 05:49 PM
