2000 S40 1.9T with 23 Check Engine Codes + more
Old Sep 7, 2013 | 01:22 PM
midimykeys's Avatar
Default 2000 S40 1.9T with 23 Check Engine Codes + more
I bought a 2000 S40 with 169k the other day. The check engine light was on, but I figured at the low price of $1400 it was probably something manageable. Codes for air assisted control valve, turbo/super charger wastegate solenoid "A" low, evaporative emission system purge control valve circuit shorted, h02s heater control circuit bank 1 sensors 1 and 2 (to name a few). Plus the ABS, airbag, brake light, and flashing shift-up light intermittently appear in the instrument panel. There is no rhyme or pattern to these lights. Once the car got stuck in "winter mode" when the flashing shift-up light was active.
My question is: is it possible that the electrical system is faulty? I mean, I guess anything is possible, but the car seems to be running just fine, other than getting stuck in winter mode once. Has anyone heard of a faulty check engine system?
Old Sep 7, 2013 | 04:36 PM
difflock54's Avatar
Try clearing the codes and CEL and see what happens.
Some may be old fault codes not properly cleared previously.
850NIK
Dec 28, 2012 01:30 PM
gordon368
Jun 6, 2009 03:01 AM
erndawg
Mar 20, 2009 11:58 PM
gabyman97596
May 14, 2007 09:52 PM
