2000 s40 driving problem
Old Jan 26, 2011 | 11:05 AM
kxmadman's Avatar
Default 2000 s40 driving problem
Normally when I am driving over 40mph the car will kick to the left or right when I hit a bump in the road. It almost feel like the back end of the car is sliding on ice, but the road is dry. Any help please. 160k on the car.
Old Jan 26, 2011 | 02:51 PM
Mad Matt's Avatar
How's your alignment???
Old Jan 26, 2011 | 04:02 PM
kxmadman's Avatar
recently aligned, tires rotated and the same problem exists. thought about strut problems or control arms? but uncertain as i have jacked the car up and checked for play.
Old Jan 26, 2011 | 07:31 PM
Mad Matt's Avatar
That is interesting. What about bad bushings???
Other then that I really don't know what could be causing it. You might want to ask over at S40concepts.net to see if any of those guys have came across the same issue.
Old Jan 27, 2011 | 08:07 PM
Scotland77's Avatar
Is it the front or the back that kicks??, is it when you are driving in a straight line or when on a bend?
More info please
Old Jan 28, 2011 | 10:46 AM
kxmadman's Avatar
Feels like the back of the car, most noticeable on the express ways at higher speeds. straight line
Old Jan 28, 2011 | 06:45 PM
Scotland77's Avatar
Might sound strange, but how are your rear shocks??
A different design, but my truck would do the same thing. the rear shocks were so worn that whenever I went over a bump, the rear end would actually leave the ground for a split second and it would jump sideways a little.
Does it only do it in a straight line?, or does it also do it on turns?, any worse any less?
Old Jan 29, 2011 | 04:16 PM
kxmadman's Avatar
Shocks seem fine but i think they are the originals, and the car does have 160k. its hard to duplicate pushing down on them vs. real world driving, but i think that is the problem. Now I am getting noticeable noise from the front pass. side suspension. Sounds like crumpling up a paper bag every time i go over a dip or speed bump very slow. It is more noticeable when it is very cold out.
Old Jan 30, 2011 | 07:15 AM
Scotland77's Avatar
Don't know what that could be unless there is a bunch of snow and ice up in your wheel well...
Can you replicate that sound by bouncing the front end up and down
jweston5
Jan 5, 2010 07:50 AM
timxxx
Dec 21, 2009 01:20 PM
Bonkajs
Jun 18, 2008 03:47 PM
jmc00v70
May 26, 2006 04:16 PM
