2004 S40 T5 O2 sensors
Old Oct 27, 2018 | 01:35 AM
utan's Avatar
Default 2004 S40 T5 O2 sensors
Hi there guys and gals!
I have my son's S40 2004 with 140k with O2 sensor problems.
Diagnostic tool says
P0031 : HO2S Heater control circuit Low bank 1 sensor 1
p0037 : H02S Heater Control Circuit Low Bank 1 sensor 2
I replaced sensors cleared ECU and it came back again in less than 20 minutes driving..
I've checked the Harness connector I am getting 3 volts instead of 12 v but Am unsure this is the correct value on VOLVO .. I am a do it myself person.
I Checked the fuse box and none is tagged with O2 sensor feed label or such ...
is the 3v value correct ? , or what's the correct value?
Any help greatly appreciated..
Old Oct 27, 2018 | 01:10 PM
habbyguy's Avatar
Check fuse F33 under the hood...
Old Oct 27, 2018 | 01:30 PM
utan's Avatar
Hi,
thanks for your reply, is that one called something around light bulb fuse?
its was blown and I replace and blow it again, I have the car with mechanic doing water pump replacement.. so i am unsure if same fuse that your showing here..
so it should be more that 3 volts.. then..
i knew it could be a fuse.., when i get the car back I will come back here..
Thanks.. for ur help.
Old Oct 28, 2018 | 01:34 PM
utan's Avatar
Hi,
The fuse keeps getting nailed, I check harness cables for any short disconnected O2 sensors to see if they are not the culprit but nothing, I was reading somewhere that it could be vacuum pump circuit for brake servo ?
@habbyguy you have more information , i really appreciate your help.
Old Oct 29, 2018 | 12:17 PM
volvowiringdiagrams.com may help - check out what is on that fuses wiring path...
Old Oct 29, 2018 | 01:09 PM
utan's Avatar
thanks mt6127,
But that website volvowiringdiagrams.com is on error..
Old Oct 30, 2018 | 02:55 AM
utan's Avatar
was shorted, now old and new sensors are working fine.
thanks for kind support.
cochran3
Feb 6, 2017 10:17 AM
Pubcha
Mar 14, 2014 11:01 PM
s40volvo
Jun 6, 2012 12:07 PM
joelq
Jun 12, 2011 03:36 PM
fv70tech
Sep 24, 2009 07:14 PM
