2005 S40 won't stay running
Old Nov 27, 2019 | 02:21 PM
Azhrei's Avatar
Default 2005 S40 won't stay running
hi
I now have my daughters car that she left for me to deal with while she went to Alaska.
2 things that had an issue that I knew of
1. vacuum leak.
2. battery will go dead after 2 days of not driving it. brand new battery!
well it has a 3rd problem that evidently worked it self out before. and it will be a hard sell if I can't fix it.
I can start the vehicle and RPM's are at 1800 and after 5 seconds it stalls as though it runs out of gas, I can get it started most times right back up but same exact behavior.
there are times it will be about 800 RPM's and last may be 30 seconds
I replaced the sensor on the fuel rail with one I pulled from salvage yard. and still the same behavior.
I got a fuel pressure tester which I will try to get some readings.
what am I looking for?
thanks
Paul
Old Nov 27, 2019 | 02:34 PM
Azhrei's Avatar
Default additional info
even with my foot on gas pedal it will not stay running it will always stall!
Old Nov 27, 2019 | 09:46 PM
habbyguy's Avatar
I'd suggest that you should look for the vacuum leak - it might be the cause of your idle issues. Then you can look for what is draining the battery...
Old Nov 28, 2019 | 09:49 AM
Azhrei's Avatar
hmm but the vacuum leak has been before this issue
Old Nov 28, 2019 | 12:57 PM
Azhrei's Avatar
I just checked the pressure and while running it was about 8-10 psi. when I first hooked it up it was 0
I didn't notice if the fuel pump came on or not... how quiet are they in the s40?
Old Nov 29, 2019 | 10:58 AM
habbyguy's Avatar
My 2005 V50 used to run 55psi (IIRC - it was something in that range, anyway). I never had to work on my Volvo's fuel system (happily) - most modern cars have the fuel pressure regulator in the fuel pump itself - others are external, and may have a vacuum connection (obviously if this is the case, you're going to want to try to figure out that vacuum leak).
igmo
May 8, 2018 03:29 AM
khanss9
May 10, 2015 06:04 PM
motofrk75
Mar 16, 2015 09:02 PM
Sawwantha
Jun 10, 2012 09:02 PM
icthus
Mar 12, 2012 04:05 PM
