2007 S40 rear brake caliper removal
Old Dec 29, 2018 | 01:09 PM
k1s40's Avatar
Default 2007 S40 rear brake caliper removal
I am going to replace a bad caliper and need help removing and reattaching parking brake wire to the caliper, pictures will help more.
also removing the brake fluid hose to caliper, I wander how to avoid air getting in brake hose.
Old Jan 1, 2019 | 02:46 PM
pierremcalpine's Avatar
replacing a flex hose is pretty straight forward stuff. Some searching on YouTube will give you all the info you need. As for how to unplug he EPB, it’s just a clip harness. Do a search for volvo EPB removal to get diy instructions on how to deal with an electronic ebrake without using specialized tools.
Old Jan 2, 2019 | 03:16 AM
k1s40's Avatar
2007 Volvo S40 does not have EPB
Old Jan 2, 2019 | 03:18 AM
k1s40's Avatar
Old Jan 2, 2019 | 02:52 PM
When I did the rear caliper on my 850, I kept a golf tee handing to stopper the line. When I reattached it took some fenagling to get the hard line to thread in so I created a small puddle of fluid, but I simply opened the bleed valve and let the fluid run through to push any air out. Did a very simple open close with a helper pressing on the brakes and that was it for bleeding. I suspect the S40 will be much the same. All you need is a clear tube bleeder hose to see if any bubbles come out.
Mongoheadache
Nov 3, 2015 12:35 PM
vikiius
Feb 17, 2014 07:59 AM
jym-d
Mar 5, 2012 07:14 PM
Counselor828
May 18, 2009 09:58 PM
ddub
Apr 15, 2009 10:34 AM
