Brake Fluid Level Low Message 2008 Volvo S40 Lvl Is Full
Old Mar 3, 2020 | 09:07 AM
weshamm's Avatar
Default Brake Fluid Level Low Message 2008 Volvo S40 Lvl Is Full
Hello All
Hopefully someone can help me with this
I have a message that my brake fluid level is low stop safely with a large triangle in the center display also the BRAKE light is on as well (not the hand brake light it works fine)
I checked all pads they are fine.
.I attached a photo of dash
My brake fluid is full ?
So I assumed it was the level indicator float gone bad.
I removed the terminal from to the sensor clip and jumped with a small wire to complete the circuit
attached a photo.
I still have same message
Is there some other sensor that could be causing this issue?
Hopefully someone has had this issue and knows the cure to the triangle and the message.
Thanks all for any input.
Wes
Sssnake
May 27, 2022 06:55 AM
michaeltroy
Jan 5, 2015 08:17 AM
ChrisHuntze
Jul 7, 2012 01:52 AM
slimflex2
Jan 23, 2012 11:20 PM
bluedevilbill
Jun 18, 2008 05:42 PM
