Brake light false alarm?
Old Aug 25, 2019 | 09:25 PM
Sarah Necessary's Avatar
Default Brake light false alarm?
I got a 2006 s40 a few weeks ago. It's never been in any accidents, and only has roughly 60k miles. I haven't had any issues, but today while stopped at a red light, the Passenger Airbag Failure light came on, along with the Brake Failure stop safely sign. It was really fast- like maybe 10 seconds, and then they turned off. The car drives fine, I didn't notice any problems at all. Just those lights turning off and on once. Should I be concerned?
Old Aug 26, 2019 | 08:07 AM
habbyguy's Avatar
It's unlikely that you'd have an actual failure in both systems simultaneously, so it's got to be something common. A bad alternator and the associated dying battery will often produces multiple seemingly unrelated "failures" (warning lights and messages) though if you don't have any other symptoms of a low battery, this isn't likely to be the problem. I don't think I'd get my knickers in a twist over a single 10-second "blip" like yours, but if it repeats, I'd look into what the common point is for those two systems (one of many modules in the car), and go from there.
Old Aug 26, 2019 | 12:32 PM
Thank you, that was what I was thinking. It was such a short message, and I haven't had it again, so I figured it was probably (hopefully) nothing worrying about. I'm just super paranoid since I just bought the car.
Old Aug 26, 2019 | 01:26 PM
just to be on the safe side, I'd probably take a look at the brake fluid reservoir just to make sure its at the appropriate level. Also sometimes the SRS connectors for the seat sensor can get bumped which can set off a fault code. SRS fault codes (aka airbags) will be stored in the computer but not all scanners read the SRS codes. A quick scan can tell you if anything was captured by the computer. You can borrow a scanner from most big box parts stores like Autozone. If there is a code, write it down then clear it. If something is truly amiss, the code will reappear.
og610
Dec 12, 2023 10:42 AM
stichn56
2001-2013 model year XC70
May 16, 2015 10:50 AM
jadalber
Apr 7, 2011 06:51 AM
crosby1
Dec 29, 2010 11:02 AM
JCVolvoS80
Feb 12, 2006 02:06 PM
