Cam Seal plug / adhesive or just press fit?
Old Jun 16, 2017 | 04:30 PM
Nismou20's Avatar
Default Cam Seal plug / adhesive or just press fit?
About a year ago I repaired a blown HG and the cars been running just fine. This morning went to check the oil level and noticed oil covering the throttle body area and found that the cam cap/plug was halfway separating from the head. I only used a drift to install last year but is this supposed to be pressed in with an adhesive?
Old Jun 16, 2017 | 06:02 PM
Hudini's Avatar
It's just press fit. Some RTV won't hurt though. I would check if you have back pressure from the oil fill. Just in case there is more going on like a clogged PCV system.
Old Jun 17, 2017 | 08:30 AM
pierremcalpine's Avatar
What Houdini said - check your PCV before other seals start popping out!
lionhearted1
Mar 28, 2023 03:23 PM
TDolce
Mar 19, 2013 01:58 AM
Tuscanybill
Aug 13, 2010 11:12 AM
WalterXI
Apr 9, 2010 01:36 PM
buzzforb
Sep 13, 2007 08:40 AM
