Code P0442 evaporatve emmisions system leak
![Question](https://volvoforums.com/forum/images/icons/icon5.gif)
I just purchased a 2001 S40 with 1.9T. i get an intermittant CEL. I get two codes; P0442 (evaporative emmissions system leak detected) and P0128 (coolant temperature below thermostat regulating temp.) Also when starting the engine it takes about 5-10 seconds of cranking before the engine starts. Can antone give me some help on determining exactly what I need to do to solve the starting issue and resolve the code issues. Are the code issues related to each other and/or related to the starting problem?
Thanks Tech, I checked the cap, it looks ok. could the temp sensor cause the starting problem? Could the evaporative emmissions problem cause the starting problem? Are these codes cleared if problem is intermittant? Light seems to only come on at first starts, then stays on for a while ( day or two) Then doesn't appear again for awhile.
I had a valcum leak code aand the Volvo dealer said Gas Cap ,it was replaced The code returned after next fillup, now dealer saysthe J hose is leaking ... They want $329.00 to replace the Little Wee J Hose..
I think it is less expensive to just cancel the code when it appears every so often
![Confused](https://volvoforums.com/forum/images/smilies/confused.gif)
Thank you for the post,I first visually checked the cap and saw no issues, after a few days I took emery cloth to the fill neck area where the gas cap seats, and cleaned the gasket on the gas cap with some strong solvent to soften it up. It's been about a month now and I haven't gotten the code. Hope I'm good to go. If it comes back I'll look at the J hose situation.
![Smile](https://volvoforums.com/forum/images/icons/icon7.gif)
Still have the starting issue and still get the temp code about every month. I've decided to change the Therm stat and temp sensor to solve that problem. Just haven't had the time to get into it. If I still have the starting problem after that I will replace the Fuel Pressuer regulator. I'll keep you posted.
https://www.fcpeuro.com/products/volvo-reference-sensor-rpm-30713485
https://www.ipdusa.com/products/22205/Crank-Speed-Sensor-Bracket-5-Cyl-Genuine-Volvo-30637803
![](https://cimg7.ibsrv.net/gimg/volvoforums.com-vbulletin/1438x1602/screenshot_20240310_103438_chrome_a03c35106bf207a831b5e4bc5cd8ebca48bea01b.jpg)
![](https://cimg3.ibsrv.net/gimg/volvoforums.com-vbulletin/1438x1483/screenshot_20240310_103408_chrome_705fc10a89e08c6453b29c7347128959aa01b600.jpg)
![](https://cimg4.ibsrv.net/gimg/volvoforums.com-vbulletin/1402x1075/screenshot_20240310_103617_chrome_f30edb12c3c3433325335fd74bb082763fd72485.jpg)
d33dvb (04-18-2024)
aldavjr
10-18-2011 08:57 PM
