CODES
Old Dec 19, 2008 | 09:16 PM
  #21
hordezla's Avatar
Default RE: CODES
Oh shoot. Bent valves, major pita, big bucks.[:@]
Any idea where I can buy this tool?
Old Dec 20, 2008 | 06:46 AM
  #22
Default RE: CODES
Not off hand. I have heard the Dealer wants almost $500.00 just for the tool.
Here is the link to the site I got the pic from. They want $500.00 for the master kit maybe contact them and see if they will sell the cam tool seperate.
http://www.zdmak.com/wbstore/main.as...=VOLVO%20TOOLS
Old Dec 23, 2008 | 08:30 AM
  #23
hordezla's Avatar
Default RE: CODES
Tech,
I found a place that sells them separately, cam lock tool alone is $224. I am going to buy that one.
If it turns out that valves are bent and I need to take the head out, can I manage without these other tools you posted above or I need to have them all?? Anotherwords I dont know if I should just buy the whole set 'cause I might need it?
Old Dec 23, 2008 | 08:36 AM
  #24
Default RE: CODES
Well it is nice to have the 2 long tools with the wingnuts but you can do it without it.
Actually we made one at work. Welded some angle iron and cut some notches so it sat on the cam cover. Then broke some spark plugs and welded threaded rod to them and used the tool like that and ot worked fine. It is to help remove and install the cam cover straight.
If you don't have it you have to press the cam cover down slowly with the screws.
Old Jan 5, 2012 | 07:34 PM
  #25
jfisk60903's Avatar
You've driven the stake in the yard for sure now, Never Pull the timing gears off a overhead cam engine without the cams being locked, preferably locked on the timing marks (all 3). I have a feeling you just spent 1500 on a valve job to go along with the new VVT hub. Always look in the pool before diving in. Wow
gabyman97596
May 14, 2007 09:52 PM
TBoone
Aug 8, 2006 12:52 AM
cranky
Aug 5, 2005 09:46 PM
pitar
Apr 2, 2005 11:37 PM
