Driver seat has too much play
Old Mar 3, 2011 | 11:54 PM
lukaspanic's Avatar
Default Driver seat has too much play
2000 S40: when I accelerate or brake hard I can feel the seat moving slightly. it is not bad but annoying and I'd like to fix it. It does not seem to be the bolts holding the seat assembly to the car floor. It seems like the seat has too much play inside the rail. Is there a way to tighten that up?
Old Mar 4, 2011 | 03:09 PM
wgmiller's Avatar
Not sure if you're still under warranty or not, but my '06 T5 did the same thing. I believe there was a technical service bulletin on this and my seat was fixed. Can't remember exactly what they fixed, but it doesn't do it anymore.
Check into at your local dealer...
Old Mar 4, 2011 | 10:09 PM
lukaspanic's Avatar
I'm not under warranty anymore, 141k miles. I think however all recall issues have been fixed, at least thats what the latest CarFax tells me. I'll ask the dealer anyway, maybe they know what it is.
Old Mar 5, 2011 | 10:01 AM
SgtCheeseNOLS's Avatar
If it is a recall, regardless of miles and warranty, they must fix it. So you can take it in for that if it is apart of a recall.
Is the seat portion sliding, or the back rest moving? Because I notice the backrest move a bit when I brake or accelerate in mine.
Old Mar 10, 2011 | 04:45 PM
Counselor828's Avatar
Hi Lucaspanic. I have the same "seat rocking" issue with the driver's seat in my 2000 S40. Let me know what you find out please. Post back so we can all learn with you. Thanks much.
Old Mar 12, 2011 | 01:37 AM
lukaspanic's Avatar
I haven't had the time to deal with the seat issue yet since I also have/had suspension, transmission, oil leak and a few other issues.
I will however report back whenever I find out more.
Old Mar 12, 2011 | 09:47 AM
wgmiller's Avatar
I pulled my service receipt for the repair and it stated that I had a faulty seat back frame. The part was replaced and the seat has been fine since. Not sure if this is the same problem as yours or not...
Old Mar 16, 2011 | 03:20 PM
lukaspanic's Avatar
I still haven't had the time to fix it but I did a little wiggling while sitting at a red light and iy is tue whole seat having too much play on the rails. Just wanted to add that.
boggy
Nov 4, 2011 08:22 PM
aryanvahedi
Nov 18, 2009 08:59 PM
charlieruss
Aug 25, 2006 07:46 PM
yellow95
Apr 22, 2006 12:42 AM
S70turbo1999
Mar 30, 2006 07:18 AM
