help please: S40 hissing noise front right
Old Dec 12, 2009 | 10:55 AM
arne's s40's Avatar
Default help please: S40 hissing noise front right
my s40 was hit (low speed collision) in right front wheel area. There is a high pitch hissing noise that reacts to steering wheel movement and braking. Any suggestions as to what is damaged? Thanks for your inputs!
Old Dec 12, 2009 | 10:07 PM
AutoNaut's Avatar
What year is the car? The 2004.5+ has an electric power steering pump near that location that can make a high pitched hissing noise.
Stan
Old Dec 13, 2009 | 08:38 AM
arne's s40's Avatar
thanks AutoNaut. it's 2010 s40 - it that pump thill there? I would apreciate an info as to a good service manual for an s40.
Old Dec 13, 2009 | 01:38 PM
deucetech's Avatar
The pump is still is the right from corner. There are also belts in the right front. The fluid may also be leaking from a power steering hose in the same area. Either way if it reacts to steering wheel movement, it is something power steering related. If it also reacts to braking, there could be something else at play. Here's my advice. If the car doesn't look damaged or if its been fixed already, take the car to the dealer. Its still under warranty. Play dumb on the collision. Tell them it was never hit. If they catch on, and won't cover it under warranty, have them tell you what's wrong, and how much it will cost, then take it somewhere else and have it done for less.
Old Dec 13, 2009 | 01:45 PM
arne's s40's Avatar
Deucetech: thanks for advice. I'm doing the body work now. And there are no leaks. It should become clear soon whats at fault. Jacek
hopps1945
Aug 30, 2015 01:04 AM
Marvin Lee
Jan 25, 2013 07:40 PM
xxjoeyxxeb
Oct 3, 2007 04:05 PM
kaz
Jul 7, 2006 01:11 PM
