how to reset codes on a 01 S40
Autozone, Advance, etc can erase the code for you free.
If you have some cash go for a Harbor Freight el cheapo OBD-II reader. If no Harbor Freight nearby then your local auto parts store has them for a little bit more. The 2001 only needs the simplest one. New Volvos need the CAN BUS compatible readers.
The work around is to borrow the reader and erase them yourself. If they won't let you use it without their help then you are stuck with buying one.
Here is the lowest cost Harbor freight one on their website:
CAN OBDII Code Reader with Multilingual Menu
Looks like even the cheapest one is CAN compliant.
youanimal55
01-19-2009 01:23 PM
gabyman97596
05-14-2007 09:52 PM
