Non turbo block
Old Apr 18, 2019 | 10:25 AM
usmarine0905's Avatar
Default Non turbo block
Hello to everyone... Did Volvo make a 2.5 non turbo? And if so can it be converted to a turbo model using the same block.?
Old Apr 18, 2019 | 12:21 PM
check out the "Volvo Modular Engine" Wiki page to see all the variants of the motors. The NA motors run a higher compression ratio than turbo motors so while conversion is technically possible, it would not be advised as you'd be adding boost on top of high compression which would mess with the fuel mapping and cause pre-ignition on anything short of aviation gasl...
Old Apr 18, 2019 | 04:00 PM
@mt6127..... thanks. I came across a 2.5 non Turbo engine, my current is, was going to have the short block serviced and use my parts to build. Ok no it is
Old Apr 18, 2019 | 04:58 PM
I suspect the pistons and cams are different but you'd need to check part numbers etc to see if the block/crank etc is the same for two engines with the same bore/stroke.
Old Apr 22, 2019 | 06:04 AM
Hudini's Avatar
2.5L non-turbo? Out of an 90's model 850?
Old Apr 24, 2019 | 06:54 PM
thank you
Wesley brown
Apr 27, 2014 11:14 PM
Kyle Olson
May 5, 2013 08:46 PM
someday70R
Sep 18, 2008 05:40 PM
1998bluev70owner
Apr 9, 2008 08:20 AM
MattB850in
Apr 10, 2007 07:55 PM
