Power Steering Erratic S40 2004.5 2.4i
Old Feb 21, 2018 | 12:41 PM
CG2000's Avatar
Default Power Steering Erratic S40 2004.5 2.4i
As I turn the wheel I get no power steering assistance for about the first 5 to 10 degrees. As I turn harder to get it to move the power steering suddenly kicks in and since I'm pushing hard the steering (and the car) then jerks over in that direction until I can react and correct.
This only happens on a cold morning, after about 10 mins of normal driving it starts working fine. I can get it to work sooner by working the wheel back and forth through the dead points while waiting at the lights.
When in for brake change I had the mechanic check the fluid, it looked clean and at correct level.
Is this likely a pump problem? A sensor problem? What should I try changing first?
Its a S40 2004.5 2.4i
Old Feb 24, 2018 | 07:37 PM
Hudini's Avatar
Your description sure sounds like a pump issue. Just a guess.
discoe
2001-2013 model year V70
Oct 26, 2017 03:19 AM
AGSchear
Oct 19, 2012 08:26 PM
nybblesandbytes
Feb 16, 2012 09:58 AM
49willard
Sep 30, 2010 10:28 AM
49willard
Sep 26, 2010 02:42 PM
