Removing clear plastic window from dash board
Old Jul 22, 2015 | 02:55 PM
Newport_j's Avatar
Default Removing clear plastic window from dash board
I have a 2002 Volvo s40. I would like to remove and clean the plastic windows that sits in front of the gauges for speedometer and tachometer, plus clock and other adjustments.
The plastic window is dirty and needs to be cleaned. Is there a way to remove on my Volvo s40, clean it and then put it back on my car?
Any help appreciated. Thanks in advance.
Respectfully,
Newport_j
PS I hope this is easy. I am afraid it is not.
Old Jul 22, 2015 | 08:55 PM
TEEKAY's Avatar
You can do this. But huge warning, don't pry up any of the white tabs. They will almost certainly snap with any amount of force. The clear shield should have tabs you can push down and once all are depressed it will slide off the front. See this album of a 03/04 cluster I dismantled.
Tearing Open an S40 Cluster (03/04) - Album on Imgur
As far as getting it out of the car. There are a few screws you remove and you can pull it out through the front with the wheel position lowered. There are two connections on the back to unplug.
Old Jul 29, 2015 | 08:19 AM
Newport_j's Avatar
Now I am just talking about the plastic, clear sheet on the dashboard. It covers the speedometer, tachometer clock and odometer. This can be removed, cleaned and then replaced on the 2002 Volvo s40 without too much trouble?
Thanks in advance.
Respectfully,
Newport_j
Old Jul 29, 2015 | 09:22 AM
TEEKAY's Avatar
You need to remove the cluster to remove the shield. It's attached to it.
tech
Oct 10, 2017 09:43 AM
mark2765
Oct 10, 2012 05:31 AM
tr_car_nut
Jan 19, 2008 09:37 AM
jpirish
Dec 17, 2006 05:27 PM
TonyS40
Nov 24, 2006 05:07 AM
