s40 brake fluid dot 4 vs dot 4+
Old Jul 29, 2009 | 02:59 AM
bigvolvo's Avatar
Default s40 brake fluid dot 4 vs dot 4+
i just bought a new 'used' 2001 s40 and noticed in the manual that the brake fluid is supposed to be dot4+.
i searched in internet about dot4+ but could not find any info. all there is difference between dot3 and dot4.
my local volvo dealer wants $20 for a quart of dot4+. all i need is just to top up.
can i use dot4 which is available in discount autoparts ?
thanks.
Old Jul 30, 2009 | 05:19 PM
Counselor828's Avatar
Default Dot4 vs. Dot3
No Problem on the Dot4. It is what you want. I just did a fluid change myself with the Dot4, and all is fine. The difference between Dot3 and Dot4 is the higher tempurature limits for Dot4. That means the Dot4 product will withstand tempuratures of about 50 - 75 degrees higher (+/-) that Dot3. The volvo braking system does need the Dot4, so make sure you get it, not Dot3. So go to the parts store and get it (for about $5 -$8). No need to go to the Stealer. Good luck.
Old Jul 31, 2009 | 02:12 AM
bigvolvo's Avatar
Thanks much. I will do that.
mt6127
Feb 4, 2015 10:32 PM
Volvo850youngone
Aug 15, 2010 12:31 AM
gquodala
Oct 31, 2009 07:16 PM
Flying torquewrench
Apr 3, 2006 08:20 PM
