Squeaking noise during decelerating and low rpm speeds
Old Mar 3, 2017 | 08:19 AM
darkblueS40's Avatar
Default Squeaking noise during decelerating and low rpm speeds
There's a squeaking noise ("eek-eek-eek") emanating from somewhere under the hood of my '98 S40 whenever I lay off the throttle, and whenever I slowly brake to a halt. And the noise makes a racket in car park speeds (around 20 to 30 km/h). Only when the car speeds up the noise goes away.
What's causing the squeaking? It's been driving me crazy!
UPDATE: During a hour-and a half long drive, the noise gradually went away as I neared my destination.
Old Mar 3, 2017 | 03:52 PM
does it do it when the engine is running in neutral and the car is not moving? If it only happens when the car is in motion, then I'd check the brake pads - I've seen them lose all the pad surface and metal on metal makes a terrible squeak...
Old Mar 5, 2017 | 07:05 AM
pierremcalpine's Avatar
Might be the aux belt tensioner- can you hear it when you open the hood parked?
Old Mar 6, 2017 | 06:38 AM
It only happens when the car is moving. thanks!
Old Mar 6, 2017 | 06:40 AM
Only popped the hood to check when I did the morning cold start. Did not hear the squeaking. Will look again in different conditions. Thanks!
XC70AA
2001-2013 model year XC70
Aug 19, 2020 06:48 PM
Alcrop
Sep 18, 2015 07:19 AM
christopherandrews1989
Jan 7, 2015 09:03 AM
Wing0
Dec 13, 2013 02:39 PM
s70belgium
Jul 1, 2009 06:05 PM
