Volvo S40 issue with seatbelt sensor
Old Apr 28, 2024 | 04:16 PM
Macedo's Avatar
Default Volvo S40 issue with seatbelt sensor
Hi guys, i recently bought a volvo s40 ii 2006. Im having a weird issue with the front passenger seatbelt sensor. Every time I have a passenger and they exit the car, the sensor still thinks someone is sitting there and will activate the missing seatbelt logo and start to chime. There is nothing on top of the seat and it will just beep, I have to push down on the seat with my hand a couple of times for it to stop. Is there a way to fix this? Im guessing its probably just a faulty sensor or it might be just out of place?
Old Apr 28, 2024 | 09:51 PM
Niklas11Braun's Avatar
First, I'd check the sensor and wires for any damage. If they look good, try the mounting bolts and repositioning the sensor. If that doesn't work, a system reset might help. Just disconnect the car battery for a few minutes, then reconnect it. This can reset the car's computer and probably fix the problem.
Also, maybe the issue is with the pressure sensor in the seat cushion. Over time, it might wear out or shift, giving wrong readings. You can check this by putting something heavy on the seat and then removing it to see if the sensor still thinks someone is sitting there. If it does, the pressure sensor could be the culprit.
Old Apr 29, 2024 | 06:09 PM
Macedo's Avatar
Thanks for answering, I’ve looked at the wiring and it seems fine, no damage there. I’ve tried putting weight on it, and in 10 times it does it once or twice, so its not consistent. When I have some time I will definitely try taking it apart and remounting it that might be it. I’ll come back and tell you how it goes. Thanks
Mick820
Jul 31, 2022 05:08 PM
Dunlin1
Volvo XC40
Aug 24, 2021 03:54 PM
Paulwolf01
Jul 10, 2019 12:04 AM
Racho Kovacha
Aug 20, 2012 08:04 AM
denver005
Oct 18, 2009 10:08 PM
