WATER LEAKING INTO CAR
Old Aug 27, 2016 | 08:46 AM
  #21
pietro_07's Avatar
Default Check this video
Originally Posted by phobod1
for the past couple months or so ive noticed that my floors have been moderately wet after it rains. after some investigation i noticed water was spewing down from under my dashboard. the local volvo dealer wanted 150 an hour to work on it and wouldnt actually tell me what was happening. if anyone can please help me out ide appreciate it
Old Feb 8, 2017 | 12:17 PM
  #22
daleroberta's Avatar
Default Wet driver floor and frost inside windshield
Originally Posted by tech
And A pillars in the front. There is 4 drains.
Where do I check for the water draining out from my sunroof drains on my 850 station wagon?
Winter in N.S.The front drivers floor is wet with puddles.
Frost inside windshield.
Also what is the best way to clear inside frost in winter? I have no garage.
Dale
Old Jun 3, 2017 | 10:07 PM
  #23
Jose Calvo's Avatar
Default Please I need someone help my first Volvo
The problem started on the rear passenger side carpet all wet. I noticed it would get worse when the air was on. So I had a mechanic unclog the AC hose under the car and now there water on all the carpets except the front passenger side. A pool of water I haven't even turned the air on cause am scared it might get worse. I also notice sometimes when I turn the air on it seems like it's struggling to stay on for the first 7 seconds. I don't wanna take it to the Volvo dealer ship. Please anyone help.
Old Jun 6, 2017 | 06:00 PM
  #24
Hudini's Avatar
It's simply a matter of identifying the leak. You have to make sure your mechanic actually fixed the issue and did not make it worse by disconnecting the AC drain hose.
Did you check the sunroof drains?
Old Aug 9, 2017 | 12:34 PM
  #25
mmugaas's Avatar
Came here looking for advice but might be able to contribute instead. There is a know problem with 2010 S40 & 2009 C30 but could be larger problem. Leak is consitently from top of windshield seal. Not a problem with sunroof drains but those can easily happen to and should be checked first. Here is a Industry News link identifying the problem. Volvo Glass Bonding Issue - Technically Speaking - Technically Speaking
Old Feb 19, 2018 | 07:35 PM
  #26
constants's Avatar
This problem is written about in several forums. Just picked up my 2012 XC60 from Volvo today. Leaked at the top of the windshield, and got worse over time. They paid for the whole repair, and even had to remove the seats to remove the front carpet to dry it out. No problem with Sunroof drains existed. They confirmed it was bad windshield seal. I didn't even have to get angry. Seems Volvo is fixing these on an individual basis. I feel bad for those who got it fixed other than by Volvo. They even gave me a loaner car. Total cost $30 in gas. Took about 4 days, mostly to dry the carpet.
Old Feb 19, 2018 | 08:04 PM
  #27
pierremcalpine's Avatar
This has been a big issue withcthe p3 v70’s and I’m guessing the same thing has happened to your v40. It is very likely the windshield that has come unglued st the top in behind the mirror. I had this happen to me and when I brought the car in to speedy auto glass the guy said he has seen several Volvo’s come in with same issue. He was able to show me the gap by pressing upwards on the windshield from the inside of the vehicle and you could see the windshield pop right up off the car. A replacement windshield will cure the isssue.
here is a link the the uk volvo forum where the v70 issue has been discussed at length.
https://www.volvoforums.org.uk/showthread.php?t=239324
Old Feb 24, 2018 | 05:32 AM
  #28
sublimeswell2's Avatar
Please see my post, "Update on My Sunroof Leak." I had this problem just after buying a used S40 as a gift to myself. The problem has now been resolved.
Old Mar 10, 2018 | 05:11 PM
  #29
FlameOrange's Avatar
Default Water Leaking into floor on 2011 C30
The first time water behind the front passenger started to appear in my 2011 C30 it was under warranty. I live in an area surrounded by a lot of trees. The dealer tech said he was going to replace the drain tubes since it was under warranty, but they could be blown out with compressed air. The second time this happened, just last year, despite my covering the car during the spring when pollen was in the air, came as a surprise. My independent mechanic (a Volvo specialist) told me he would clean out the tubes for free when I had it in for an oil change - BUT warned that the original type tubes also had a problem of getting constricted when they got older, probably the material lost its resiliency and so they could clog much easier. Sure enough, despite being cleaned out it appeared water was still getting in. So I took it back and had him install new drain tubes. $150 for the labor, $25 for the parts. However, he also told me depending on how long the problem had been going on, that the insulation below the carpet could be holding a lot of water still and that the musty odor and dampness of the carpet could continue for some time. He had the same issue with his car and eventually drilled holes through the floorboard to drain the water out. Even then, the odor did not go away. So he had to rip out the carpeting, dry out the insulation and and replace the carpet. I think mine has dried out now, and I caught it early enough. Since the problem was just in the back behind one side, I also noticed that by removing the plastic piece under the passenger seat meant to deliver warm air to backseat passengers feet (see picture) the air from my heater will then be blowing directly onto the insulation below the carpet. So I've been driving with it like that for a few weeks now and no sign of musty odor.
But the problems did not stop there. Water also got into the dome light assembly and fried the circuit for the lights. At least the sunroof switch still works. Now I'm looking to replace that on eBay. I have to say that I've never had such problems on any of the other brand of cars I've had with sunroofs. Given how common this problem seems to be you would think that Volvo would own up to this design flaw and offer to fix the problem.
Old Apr 29, 2021 | 07:12 AM
  #30
Namie Schowgurow's Avatar
Originally Posted by spideyman411
Here is an excellent 'how to' on cleaning out the sunroof drains over on Swedespeed. We are getting the musty smell in our 2005 xc90, thought it might be the drains, but they seem to be draining properly. I did not check to see if there are rear holes, will do that soon. There is water coming in but I can't find any wet carpets. I guess it could be the cabin filter housing, but it only happens after we leave it out in the rain.
Here is the how to link http://forums.swedespeed.com/zerothread?id=102526
Cheers!
-Mike
do it it can burn out ur electric seat as mine did
ed schuler
1998-2000 model year V70
Aug 4, 2011 06:56 AM
jlb1181
Apr 8, 2010 08:35 PM
GammaPoint
Dec 16, 2009 07:49 PM
freelancewagner
Feb 14, 2008 01:41 PM
aaron_c
Jan 27, 2008 12:44 PM
