Sponsored by:
Sponsored by: DashLynx
02 s60 clicking when key is turned past accessory
Old 04-24-2017, 07:00 PM
NubMech's Avatar
Default 02 s60 clicking when key is turned past accessory
The car was running rough before, but now when i turn the key on nothing happens. If i insert the key, the dummy bell sounds, but if i turn it to the "I" position, a clicking (sounds like electrical arcing) sound comes from the left of the steering wheel. I attempted to start the car and all the dash lights turned off and wouldnt come back on, so i replaced the ignition switch fuse and the fuse that has the instrument lighting attached to it. This made the lights come on again and the clicking still persisted. After changing those fuses, the electronic locking system doesnt work. Any help is appreciated, need to get this car running asap.
Old 04-25-2017, 04:50 AM
doublebug's Avatar
What about the battery?
Old 04-27-2017, 07:01 PM
NubMech's Avatar
We've tried 2 different batteries and we tried the original while hooked up to a jump starter. All of our tries have ended up with the clicking.
Old 04-28-2017, 12:39 AM
doublebug's Avatar
Looks like CEM issue but if fuses were blown it can be some shorting.
Old 04-28-2017, 04:48 PM
NubMech's Avatar
How could i test to see if it is the CEM? Before it did this i had DTCs in the ECM and PDM. Could those have an effect on this?
michelinep
07-17-2020 05:29 AM
Brady.Garcia
07-26-2011 10:23 PM
PetersonJS
05-12-2010 09:24 PM
bmangn
11-07-2009 05:12 PM
Rvillev70
09-02-2009 06:57 PM
Quick Reply: 02 s60 clicking when key is turned past accessory
