06 S60 2.5 has lost AWD
Could be many different things, Ie.. DEM may of failed, Haldex fuse blown, Spinal gear stripped. There is just too many things that can go wrong with these more fragile AWD systems to really help diagnose. Unless your wife heard any noises during the moment that the AWD failed. Best bet is probably to check the fuses (location in your owners manual) If that doesn't fix anything, it might be time to take the car in for a diagnosis.
it is possible you only need the sleeve. the only way to know is once you pull the angle of the dangle gear out and inspect it. the sleeve teeth will be worn down or missing. The sleeve is much less expensive and could be all it needs.
emmanuelhs
01-11-2008 09:27 PM
