2001 S60 T5 Transmission ?
Old Sep 13, 2011 | 02:48 PM
Roy Rogers's Avatar
Default 2001 S60 T5 Transmission ?
2001 S60 T5 Transmission hesitates going from 1st to 2nd and is getting worse. Is there common cause to this that can be easily fixed or does it need to be replaced? Thanks for any help!
Old Sep 13, 2011 | 04:54 PM
MYS6T's Avatar
[quote=Roy Rogers;288556]2001 S60 T5 Transmission hesitates going from 1st to 2nd and is getting worse. Is there common cause to this that can be easily fixed or does it need to be replaced? Thanks for any help![/quot
There are know issues with 01-02 tranys. Have not seen a T5 posted but my guess that its the same Transmissions. First look at replacing trany fluid.Flush kit from IPD and 12 qts of Volvo JWS 3309/mobil 3309/toyota t-iv ONLY do not let any one tell you that any other fluid can be used.You can also check with Volvo deal for software updates and i believe its a B4servo cover repair can be done.But this may all be for nothing in most cases when the trays starts to skp/slip its to late to do anything but replace.Dealer will use New trany $4500 with labor.Find a local Volvo shop and see if you can have a used one or even a rebuilt one used.GL
Old Sep 14, 2011 | 09:53 AM
alpac's Avatar
+ 1 on the ATF Flush kit from IPD. I flushed my 2.5t last year with it and it is an easy job. It took me 13qts of ATF to start seeing a clear red ATF out of the tranny cooling line. I used the toyota T-IV ATF as it is the same as the Volvo ATF but much cheaper, go figure!
Old Sep 15, 2011 | 08:46 AM
Roy Rogers's Avatar
Was your acting up as mine is when you did the flush? If so all is well now? Thanks
Old Sep 15, 2011 | 12:04 PM
alpac's Avatar
No mine did not have any problem when I did the flush but I read on this forum that some others have experienced big improvement in their Volvo's tranny behavior after flushing the ATF. It all depends how bad your transmission already is. I myself have experienced a significant improvement on a Ford pick up truck before and after a flush. Before the flush the transmission was starting to slip a little bit, the reverse would not engage once every 4 or 5 times and the tranny was not smooth. All of that disappeared after the flush was done. What I am saying is that the flush is easy and cheap enough, around $100 all together between ATF (if you get the Toyota one) and IPD flush kit, that it is worth trying before going to a MUCH more expensive solution. The IPD kit comes with instruction how to do the flush. It is an easy job.
How many miles do you have on your s60? Did you check the state of your ATF? is it dark and have a burning smell? Is your level of ATF not too low? This can be easily checked by looking at your ATF dipstick. If the ATF looks dark (it is supposed to have a clear reddish color) and has a burning smell I would definitely try a flush first. My 2cts
Old Sep 16, 2011 | 08:00 AM
Roy Rogers's Avatar
I have not looked to deep into the problem yet. What does IPD stand for and where do you purchase it? Thanks
Old Sep 16, 2011 | 03:15 PM
MYS6T's Avatar
Here you go Volvo Parts, Accessories and Performance Specialist Since 1963
Great company for OME and Performance parts
TurboFreak403
Apr 18, 2012 06:50 AM
auto325
Dec 10, 2010 07:47 AM
ferg32
Dec 1, 2010 05:02 PM
mstrplmber
May 7, 2009 02:26 PM
mjl
Jan 12, 2009 05:01 PM
