2005 S60 with stuck steering lock
Old Aug 23, 2013 | 12:23 AM
kahlil88's Avatar
Default 2005 S60 with stuck steering lock
Posting on behalf of a friend at work, who has a 2005 S60. He can turn the key to the first position but can't start it. Apparently he had it looked at and was told there was a mechanism in the steering column that would be $600 to replace. From what I gather, this mechanism has something to do with the steering lock and he can't get it to disengage anymore. I'm going to the junkyard this weekend, hoping to find and pull the right part for him, if I get an answer by then. I haven't personally dealt with steering lock issues, so I don't know anything about the mechanism or how it functions.
Old Aug 23, 2013 | 06:18 AM
ES6T's Avatar
A junkyard one won't work so don't waste your time. A new one from the dealer is needed because it is coded to the key. $600 is a bit high though. Should be $275 for the part plus 1.5 hours labor.
Old Aug 23, 2013 | 03:45 PM
kahlil88's Avatar
That's unfortunate. I suppose he could save money installing the part himself if it isn't terribly difficult?
Old Aug 24, 2013 | 11:22 AM
damien360's Avatar
yes 600 dollars is an accurate number. it isnt the steering column that has failed. it is the steering column lock. you have to get it from the dealer and only the dealer because they have to call and tell volvo to make the column lock. they always say it stakes 2-6 weeks to send it out but you should get it in about a week.
Old Aug 26, 2013 | 01:59 PM
ES6T's Avatar
$600 is not accurate unless you overcharge for labor at your dealership.
Obelix
Jun 20, 2022 08:40 AM
missjanelle
Sep 20, 2013 02:32 AM
stefan1988
Mar 25, 2013 10:37 AM
SKRIBZZRC
Nov 17, 2009 02:58 PM
amotin
Dec 12, 2008 09:13 PM
