Alarm not working
Hi to all,
I recently bought S60, D2. Car itself is great, so I have few questions about it, and one of it is issue with alarm.
So, when I lock the door, red light start to blink regularly but for example if I leave the window half open, then lock the car and then try to open it with my hand from the inside, nothing happens. The alarm doesn't react. If I press the red button on the key fob, the sound and the lights are activated. So it works.
If I turn on or turn off "reduced guard" everything is same.
So, what to do to see is alarm actually working?
Thank you
Thank you
What year is your car? What horns make noise when you hold the red panic button down? If it's the normal horns that's not the alarm making noise.
Siren modules go bad in the 01-07 cars. The back up battery leaks onto the circuit board and damages it. Solution is a new siren module or some have replaced the battery, and cleaned up the circuit board after cutting the plastic siren module open with a hack saw - that's the only way to get inside. Many have also done that and not been successful at the repair.
Fuse #38??
almared6
05-26-2007 11:04 PM
