Broken ignition lock and strange issues
Old Aug 25, 2019 | 04:02 PM
Grey Bearded One's Avatar
Default Broken ignition lock and strange issues
2002 S60.
The ignition key was sticking and I was thinking, "I need to get a new ignition lock." Well, yesterday, it broke. I couldn't turn the key far enough to start the car. So I rip the steering column apart and remove the ignition switch from the back of the lock so I can use a screwdriver to start the car.
Initially, the key would turn far enough to unlock the wheel and I figured that I could drive the car until I got the lock. Oh, oh, now the key won't turn far enough to unlock the steering wheel. Damn!
Then I discover that the windows won't work. Hmmmm .. . check the fuses, they're fine. Disconnect the battery, wait a bit, reconnect the battery and everything works fine. Except that I have warning messages about the ABS and airbags.
So this morning I think...."I can pull the lock off and drive the car." So I go to work on the car and discover that the windows won't work again. Hmmmmm . . .
So what could be causing this window problem? When I first found that the key wouldn't turn, I must have turned the key ten or twenty times trying to shake things loose so it would turn. That meant that I was turning the entire car on and off a bunch of times in quick succession.
Other error messages indicate brake and ABS problems that weren't there before.
Could I have screwed something up fiddling with the key as I did?
Thanks.
Old Aug 26, 2019 | 01:30 PM
did you check fuses etc?
Old Aug 27, 2019 | 08:36 AM
Not the second time. It was starting to pour and I didn't feel like getting soaked. ;_)
latemeg
Nov 11, 2025 10:06 AM
Grey Bearded One
Jul 5, 2019 06:39 AM
moonshootr
Oct 9, 2009 04:22 PM
soapmaker
Dec 9, 2005 08:59 PM
