Bulb Failure warning
Old Apr 3, 2009 | 10:06 PM
Jimbo_Jones's Avatar
Default Bulb Failure warning
All of my indicator bulbs are working on my 2002 S60, yet I am getting a message saying something along the lines of "INDICATOR BULB FAILURE". The message flickers on and off constantly. My guess is that the flickering might mean that there is a loose connection somewhere.
Has anyone else had this problem and/or does anyone know how to fix this problem?
Thanks
Old Apr 4, 2009 | 09:41 AM
You have 2 bulbs that light up per side correct?
Old Apr 4, 2009 | 10:53 AM
There are three indicator lights per side - one at the front, one at the rear, and one on the side of the car. All are working.
Old Apr 4, 2009 | 11:02 AM
The S60's should have 2 parking lights per side in the rear as far as I can remember.
There should be smaller bulbs that are the parking lights.
Old Apr 5, 2009 | 02:36 AM
I'm dealing with an issue with the indicator lights, not the parking lights.
Old Apr 5, 2009 | 09:36 AM
Then you mean turn signal bulbs? (Blinkers)
If so then check the front sockets the bulbs go into. They are very common to go bad.
Old Apr 5, 2009 | 10:41 AM
Tech: Thanks for the reply. How would I know if the sockets are bad? Like I mentioned, all indicator lights are blinking properly. The issue I have is that even though my indicator bulbs are all working, the information display has an warning saying "INDICATOR BULB FAILURE" which flashes on/off constantly.
Old Apr 5, 2009 | 11:00 AM
Does one side flash faster than the other side?
They have updated sockets.
Old Apr 5, 2009 | 12:13 PM
No, they both flash at the same speed. So you think that the problem is a defective socket?
Old Apr 5, 2009 | 01:02 PM
Could very well be.
davej
Apr 22, 2011 08:47 AM
2005s60
Jan 19, 2011 01:50 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
pingeling
Nov 28, 2007 02:17 PM
cava
Jul 28, 2006 01:39 AM
