Bulb failure warning sensor
Old Jul 27, 2006 | 03:40 PM
cava's Avatar
Default Bulb failure warning sensor
It happened to me like 3 mos. ago, I was changing a bulb in the back, turn signal, I changed it, works perfect, but after that the bulb failure sensor turns ON when I turn the headlights ON, or when I push the brake pedal, if I have the headlights OFF, no problem, but it will turn ON every single time I use the brakes, fuse is ok, I don't know where else should I look...
Old Jul 27, 2006 | 11:56 PM
Default RE: Bulb failure warning sensor
All of the bulbs working correctly?
Also make sure they all match. Either all silver Bases or all brass bases.
If you mix them that could cause the light to come on.
Old Jul 28, 2006 | 12:00 AM
cava's Avatar
Hi Tech, unless there is a bulb that I don't see or know about, all of them are working properly, I think I'll have to look at the bases,do you think I'll have to look at all of them or at wich ones should I?
Old Jul 28, 2006 | 12:31 AM
You could check them all or start with the Brake lights.
Old Jul 28, 2006 | 12:44 AM
cool_kyle_3000's Avatar
what tech said fixed the problem on my 760...good luck
Old Jul 28, 2006 | 01:36 AM
cava's Avatar
Hey Tech, could the bulb in the shifter be the problem?, now I remember that I had that doubt before..., this bulb isn't turning on.
Old Jul 28, 2006 | 01:39 AM
Not connected to the system.
davej
Apr 22, 2011 08:47 AM
2005s60
Jan 19, 2011 01:50 PM
Jimbo_Jones
Apr 5, 2009 01:02 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
pingeling
Nov 28, 2007 02:17 PM
