Camshaft and Crankshaft sensors
Old Dec 6, 2025 | 10:26 AM
15Volvo's Avatar
Default Camshaft and Crankshaft sensors
I'm kinda new to the DIY vehicle repair game, especially with anything European and built in the 21st century. My wife's 2015 S60 T5 threw a code for camshaft sensor the other day, so I've order one from Rockauto hoping that it would be a fairly easy replacement. My question is, should I go ahead and do both Cam and Crank sensors and are they that difficult to DIY? I'm not seeing a whole lot on YouTube about this repair. Thanks in advance for any info y'all can give.
Old Dec 6, 2025 | 03:20 PM
Originally Posted by 15Volvo
I'm kinda new to the DIY vehicle repair game, My wife's 2015 S60 T5 threw a code for camshaft sensor the other day, so I've order one from Rockauto .
What you should do is diagnose the problem. I can't think of any bad cam sensors I've seen with that engine. Usually if you get a cam sensor code the timing belt is not aligned correctly. When was the timing belt replaced?
(a code does not mean that part is bad, it means a control unit does not like the signal it's getting from it. And there are rational diagnostic processes that can test sensor signals.)
Old Dec 7, 2025 | 07:09 AM
15Volvo's Avatar
Since we have only owned the car for about a year, I'm going to say it's the original timing belt. How can I check to see if this is the problem? I'm trying to avoid an overly exorbitant mechanics bill. What do you consider a rational diagnostic process?
Old Dec 8, 2025 | 08:57 AM
The cam belt is scheduled to be changed every 10 years, so you should make sure it has been changed. A compatible scan tool would be helpful in finding the cause of your codes.
Domaim
Aug 2, 2022 11:19 AM
spaceboy3000
Sep 7, 2021 10:31 AM
xerxes66
May 12, 2017 03:25 PM
Maddog812
Oct 18, 2015 07:38 PM
the_brain3000
Aug 4, 2010 02:31 PM
