Camshaft position sensor
Old Jan 18, 2019 | 06:50 PM
PMOURASSA's Avatar
Default Camshaft position sensor
Hi all,does anyone here knows if the vehicle will CRANK or NOT if the CAMSHAFT position sensor(not the crank sensor) is bad.
Thanks,if you are not certain,please don,t answer,because I DON,T TO RECEIVE A million conflicting answers
Car is 2007 S60 2.5t AWD.
Old Jan 18, 2019 | 10:14 PM
ES6T's Avatar
It will crank.
I don't think I've ever had to replace a cam sensor on a P2 S60. I'd bet it isn't whatever problem you are chasing.
Old Jan 19, 2019 | 09:56 AM
PMOURASSA's Avatar
Perhaps not,but THE CAR doesn,t show any codes since none are stored,but it doesn,t crank.It only CRANK if I JUMP the STARTER RELAY,but it doesn,t start.If the starter is bad would it still Crank that way?
Old Jan 19, 2019 | 01:54 PM
ES6T's Avatar
The starter is not bad either.
Sounds like an immobilizer issue. You're going to need VIDA to properly diagnose this.
Old Jan 19, 2019 | 02:45 PM
PMOURASSA's Avatar
It can,t be that either.I have 3 xtra ones laying around,and tried all of them?Let me ask you is there a way to HARD RESET the car,s computer,without Volvo,s software,from what I read if you unplug the battery and let the power drain completely from the system,it will reset it,but I tried that nothing changed.
Thanks for your answers.
Old Jan 19, 2019 | 02:51 PM
ES6T's Avatar
The car doesn't have a separate immobilizer, so you can't have 3 laying around.
Do you get a "Start Prevented Try Again" message?
Edit- now I see your old thread. Is this still your problem?
Old Jan 19, 2019 | 03:09 PM
PMOURASSA's Avatar
yes I did get that message at first when it stopped cranking,the Immobilizers that i HAVE CAME FROM OTHER s60 same year and was told that I would not have to program it,it is just plug and play.
Thanks again
Old Jan 19, 2019 | 03:11 PM
ES6T's Avatar
The car does not have a separate immobilizer. The CEM performs this function. CEMs cannot be swapped.
If you still have your unprogrammed key from July, that's your problem.
Old Jan 19, 2019 | 03:39 PM
PMOURASSA's Avatar
But the key worked at first for a day,after the locksmith programmed it worked fine,this is what I don,t understand,anyway I think that you might be correct.I guess I have to contact a new Locksmith(But I thought that you meant the (Immobilizer ANTENNA)many qualified one in Miami,even the Dealer recommend,at least 2 that I know.
Thanks for all your help,once done .I will come back to this thread and let you know what happened.
Old Jan 19, 2019 | 05:12 PM
ES6T's Avatar
Yes, the antenna ring can be swapped from car to car.
You'll need VIDA to see if the key is being read.
the_brain3000
Aug 4, 2010 02:31 PM
flac124
Nov 11, 2009 05:49 PM
Patriq Backlund
Jan 16, 2009 09:38 AM
dragonz
Sep 20, 2008 03:31 PM
Beardog
Sep 23, 2007 07:35 PM
