Can’t ID Part 2016 V60 4cyl
Old Oct 27, 2019 | 02:57 PM
CanWeTalk's Avatar
Default Can’t ID Part 2016 V60 4cyl
Car is throwing a code for fuel pressure sensor. Multi meter indicates this part is the culprit, but I have been through parts diagrams and cannot ID it.
Part in Pic 1 is just to right of VIN number.Pic 2 is the close up.
Bolt attachment of the part is on the left of terminal connection as it goes into the part.
Thanks in Advance for any help.
Old Oct 28, 2019 | 06:33 AM
Wampo's Avatar
Is it throwing the P018C Fuel Pressure Sensor "B" Circuit Low code? If so, this was common with the 2015-2016 Volvos and have since been covered by a free repair. The details can be found here: Low Pressure Fuel Sensor Extended Warranty
However, if I'm assuming the code above is the one you have here's a diagram below of the line and sensor that come in the kit for replacement (which I did in Dec '18). The part no. for the kit is 32242867 if you want to do it yourself. But since this is now covered by an extended warranty I'd save myself the $150 and have the dealer replace it. I'm not sure what the sensor you posted is since I'm not at home to start up VIDA but it isn't connected to any fuel components and seems more proximal to the Oil Trap/Valve Cover with visual similarities to camshaft position sensors. Hope that helps but if I assumed the wrong code sorry for wasting your time ha!
Old Oct 28, 2019 | 09:20 AM
ES6T's Avatar
That's your cam position sensor. Like Wampo said, you may be eligible for free replacement of the low side fuel pressure sensor. I can confirm with your VIN.
Old Oct 29, 2019 | 08:26 AM
CanWeTalk's Avatar
Thanks did not know about recall will contact dealer
Old Oct 9, 2022 | 02:01 PM
riddickpierce's Avatar
Default Warranty details
Thanks for these comments here. For anyone else who came here - the warranty for the Fue Pressure sensor only lasts up to 8 years or 80,000 miles. Just found that out myself.
dkchandler
Sep 26, 2016 01:06 PM
zjinqui1k
2001-2013 model year XC70
Oct 10, 2012 01:42 PM
Snark
Sep 10, 2011 10:03 PM
patsfn2
Aug 13, 2010 03:00 PM
rupert77
Jan 26, 2009 06:34 PM
