Coolant low light on...
Old Feb 9, 2021 | 02:23 PM
PA-Volvo's Avatar
Default Coolant low light on...
Aside from going 30 miles to dealer for coolant, what auto parts store brands meet the spec? Until I get to USA Volvo dealer.
thanks
Old Feb 9, 2021 | 06:43 PM
thanks
Put some WATER in
Yes, you will dilute your coolant, so instead of freezing at -40 degrees, it might free at -25. If it's low you have a leak. Everything you put will be thrown away when the leak is fixed, so put some water in until you find the leak. But please make sure the antifreeze content after you put water in will protect your engine in your climate/low temp.
Old Feb 11, 2021 | 03:28 PM
PA-Volvo's Avatar
Originally Posted by hoonk
Put some WATER in
Thanks but you didn't answer my question?
Old Feb 11, 2021 | 04:06 PM
What year and model? How long are you keeping the car?
For newish cars I would use Volvo coolant and distilled water after a repair. Older cars that are flushed every 30k used the green stuff. If it's a 2001 I would just use the cheaper green stuff and tap water. A 2020 v60 I would use Volvo coolant and distilled water.
brm0220
Feb 7, 2016 08:17 PM
ranneyc
Jun 4, 2013 08:26 AM
Riculus
Feb 1, 2010 03:58 PM
Ahmed
Aug 30, 2009 01:58 PM
20carrocks
Jan 11, 2009 02:21 PM
