Does an S60 turn off if leaking alot of oil?
Old Dec 1, 2010 | 11:52 PM
ziti512's Avatar
Default Does an S60 turn off if leaking alot of oil?
My newly 16 year old daughter was driving a 2005 S60 when it died on her. Thank goodness for cell phones--she called and I grabbed the gas can only to discover she wasn't out of gas. But the car wouldn't start. There was an oil can lit up on the dashboard, so I checked her oil and it was very low. So I bought oil, filled her up, went to get gas in my car and came back. Not only would it not start, there was a fresh puddle of oil under the car--front right--and she was low on oil when I checked again. I had the car towed home because I didn't want to tow to the dealer and have them see 1) towed car and 2) female. (ka-ching, ka-ching) I am not crazy about the volvo dealership and am out of warranty.
Do volvos turn off when low on oil to protect themselves like some tools do? Or is my engine gone? Should I have a mobile mechanic diagnose the problem so i can call around and get prices before I tow? It was alot of oil so a main seal? It leaks while stopped, so... I don't know. I am praying she ran over a curb and cracked the oil pan but she says she never hit anything.
Old Dec 2, 2010 | 12:08 AM
740_300K's Avatar
I would imagine that if the PCM gets a low/no oil pressure input, that it will shut the engine off. GM vehicles have done this for the past 20+ years. If you have engine oil coming from the right front area, that could be a front crank seal that has failed, or depending on what all else is up there, turbo oil lines, engine oil cooler, and things of that nature could be up there.
Old Mar 22, 2011 | 02:48 AM
armandjones82's Avatar
If this case is still not yet solved up, you might consider to really make things work out. In that way, you can have all the other options that you could possibly can have and it would be for the good of your vehicle's needs.
Old Mar 24, 2011 | 08:42 PM
Nichals's Avatar
i know of some cars with shutoffs
but the pcm should re enable your engine when oil is topped off
its hard to burn out these engine but not impossible especially if its in a warm climate.
lexxilexxi
Feb 14, 2012 10:35 PM
ron1
Oct 22, 2007 07:48 AM
ron1
Oct 18, 2007 05:35 PM
YOLY
Nov 15, 2004 02:59 PM
