Drivers Window Sticks in either Up or Down position until I restart car
Old Oct 25, 2012 | 09:21 PM
thatbobguy's Avatar
Default Drivers Window Sticks in either Up or Down position until I restart car
My '02 S60 AWD driver's window works only intermittently - occasionally works normally, but usually either refuses to go down or back up again.
In every case, shutting off the ignition and restarting will make it work for a while.
Is there a relay panel somewhere with replaceable window relays?
Thanks
Old Oct 30, 2012 | 05:30 PM
patsfn2's Avatar
that would be the window switch on the door....if it is going bad it could cause the symptoms your describing...I would test the window switch anad if it shows it's going bad I would look on fcp groton for a replacement part!
flhpi46
Mar 9, 2013 04:08 PM
luthersdad
Aug 1, 2010 04:03 AM
chef
May 7, 2010 07:31 AM
jsheathcote
May 8, 2007 03:04 PM
WalterJ.S.
Oct 12, 2006 11:17 PM
