Fan won't stop running...
Old Aug 6, 2007 | 12:40 PM
gclin's Avatar
Default Fan won't stop running...
2002 S60 2.4L and the fan continues to run until the battery dies out. So I disconnected the power harness to the fan motor and the fan stops running. After a few days of sitting in the garage, cold engine, the fan begins to run as soon as I plug in the power harness without the key, no check engine lights. what's going on? I'm guessing it's the fan relay or temp sensor. I tried to find both and I can't find it. Can someone help me locate these items? Anybody with similar experience? Thanks!
George
Old Aug 7, 2007 | 06:31 PM
Default RE: Fan won't stop running...
The cooling fan is bad.
At one time there was a recall on the fans.
When you look at it does it have a crome box inline with the wiring or is it a black box?
Old Aug 8, 2007 | 05:31 AM
JPN's Avatar
JPN
Hi,
See if you can find a recall for the cooling fan:
https://volvoforums.com/m_66630/tm.htm
Good luck,
JPN
Old Aug 9, 2007 | 07:01 PM
gclin's Avatar
The fan has a chrome box inline. I checked the recalls and it looks like there is a recall for 1999-2001 S60 fan assemblies... however mine is a 2002 S60.
Old Aug 11, 2007 | 09:56 AM
You also have the new style fan anyway. That bad part is if it is bad you will need to pay for a replacement.
They are somewhat common to go bad.
Old Aug 13, 2007 | 03:56 AM
gclin's Avatar
So in the S60, there is no separate temp sensor or relay? All one piece on the fan assembly?
Old Aug 13, 2007 | 05:30 PM
Yes thats how they set it up.
There is a temp sensor seperate but the check engine light would be on and the car would usually run like crap if it was bad.
The cooling fans are a pretty poor design.
Old Aug 15, 2007 | 03:14 AM
gclin's Avatar
Thanks for your expertise! Really helpful!!
Old Mar 23, 2012 | 12:45 PM
flyguyaaron's Avatar
Any one figure out what needed to be replaced, mine is stuck on now
dadlovsyall
Oct 2, 2015 10:56 AM
salazarbuchan
May 16, 2012 06:03 PM
pnhons
Nov 20, 2011 05:26 PM
leonardd
Aug 6, 2011 06:48 PM
bencops
Dec 29, 2010 03:51 AM
