Help with trouble shooting
Old Oct 4, 2017 | 08:26 PM
Jay Boyd-Stofleth's Avatar
Default trouble shooting codes and evap
2001 volvo s60 2.4t
codes thrown
P0447 evap is thrown before check ingine light comes on. Then check ingine comes on and P0304 cylinder 4 and then 5 P0305 then P0300 multiple cylinders codes are triggered.
Replaces fuel injectors and changed the cylinders around but same codes. cylinders are good. Changed plugs.
Car ideals rough and loud. No power and cuts out until rpms are higher. Can smell gas when starting and running.
Any help with this would be most appreciated.
Also wonder ing can evap throw cylinder codes?
Old Oct 24, 2017 | 08:06 PM
moved to S60 board. Also check for vacuum leaks and it sounds like you may have an issue with the fuel pressure regulator/sensor.
RedTurbo850
Jul 8, 2011 01:34 PM
StrlngSlvr06
May 4, 2010 08:03 PM
dadto5
May 24, 2008 01:46 AM
84B23F
Apr 20, 2008 02:18 PM
scubblicious
Oct 12, 2007 12:10 PM
