Hollow clunk from drivers side rear
Old Sep 2, 2015 | 08:03 PM
mxtraub's Avatar
Default Hollow clunk from drivers side rear
Hello
I own a 2003 s60 base and have been having this annoying hollow clunking sound when I drive over bumps. It's more noticeable when going slow. It seems to be coming from the drivers side and is only noticeable from inside the car. I've already replaced the end links and the shocks have 30,000 miles but aren't leaking. I don't know what it is
Old Sep 2, 2015 | 09:27 PM
clunks could be the strut mount assembly - ie spring seat or strut bearing. If this is your second set of struts, its possible weak after market parts were used or the strut was incorrectly reassembled. Also did you inspect the bushings/mounting brackets holding the sway bar to the chassis? After that you may need to inspect motor mounts (ie torque rods) for any torn rubber.
Old Sep 3, 2015 | 07:29 AM
mxtraub's Avatar
I forgot to mention that it's coming from the rear.
Old Sep 3, 2015 | 08:32 AM
bikerider58's Avatar
Have you checked for loose items in the trunk/boot?
Sometimes you are lucky.
Old Sep 3, 2015 | 09:11 AM
mxtraub's Avatar
Yea I've removed everything
Don98S90
Aug 3, 2015 07:08 AM
ToledoVolvo01
Apr 30, 2010 09:34 PM
robk
Mar 16, 2009 12:51 AM
jmurphboston
Mar 4, 2008 04:30 PM
JC
Sep 18, 2005 11:17 PM
