hood wont open
Old Oct 12, 2013 | 08:00 PM
newscarver's Avatar
Default hood wont open
my s60 hood wont open, the inside the car end seems ok.... it still has the ball on the cable end, it seems impossible to get to the other end at the front of the car
Old Oct 12, 2013 | 09:06 PM
Titan Joe's Avatar
You should re-read what you posted. I'm not really sure what you mean, besides that the hood doesn't open. Assuming that the cable broke, I think it will be pretty hard to open. The cable runs on top of the driver's side frame rail. You may be able to pull it there. You'd have to jack it up (put it on jack stands, don't get under it with only a jack holding it), drop the belly pan and reach up under the air filter above the frame rail and see if you can pull it. I have a few pictures of my S60R (it's a little different) that may help, but it looks like that may be tough.
Attached Thumbnails hood wont open-front_part.jpg   hood wont open-back_part.jpg   hood wont open-big_pic.jpg
Old Oct 17, 2013 | 05:40 PM
newscarver's Avatar
i thought i would try it again today after i drove it home, it opened up at the last bit of pulling , after i got it opened and checked the latches i found them dry and rusty.... lubed them up and now they work fine, so this is one item that needs to be kept lubed up for easy working release cable..thanks for looking
JeannieBeannie
Mar 6, 2019 01:29 PM
MDUBBSS70
May 28, 2014 09:02 PM
Red Tractors
Aug 20, 2013 10:33 PM
850TurboWgnPlatEd
Nov 5, 2008 12:52 PM
professor
Nov 28, 2005 11:17 PM
