Interior Lights Replacement
Old Oct 9, 2008 | 09:45 AM
DGBibo's Avatar
Default Interior Lights Replacement
Well guys and gals, a light in the center counsel/dash area went out. the passenger side climate control on the right side around the 80/red. i want to change it myself but dont want to ruin anything. is this possible? any help or instruction would be appreciated.
greg
Old Oct 9, 2008 | 11:58 AM
cjones16's Avatar
Default RE: Interior Lights Replacement
If you have a 01-04 you can switch it out, other wise I heard 05+ have LED's that cant be replaced
There pretty cheap http://www.eeuroparts.com/Main/PartsResults.aspx
once you get the climate control out you just have to take a flat head screw driver out and undo the bulb
Old Oct 9, 2008 | 02:05 PM
DGBibo's Avatar
thanks for the reply. do you know how i get the facade off? im guess a flathead or bone tool but is there a certain area to pry around? or are you saying pop off the ****?
Old Oct 9, 2008 | 02:29 PM
DGBibo's Avatar
http://www.matthewsvolvosite.c...l.php
Does this look right? and is that true at the end where is says to turn the key to II position and THEN connect the negative to the battery? i wont get shocked or fry anything right? i would think it would be connect the turn to II position. but whatever.
Capo33
Nov 22, 2014 08:01 AM
nationm
Sep 10, 2006 01:51 PM
thullz
May 13, 2006 06:46 PM
rocknroll_1950
Feb 18, 2006 09:19 AM
kosta203
Jun 27, 2005 06:38 PM
